66 mustang coupe chop top??? how?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-25-2006, 06:51 PM
thinking about chopping 66 mustang coupe, can this be done and how difficult??
Old 12-25-2006, 07:31 PM
Wiki Edits: 31
WHY?
you could do it, so the front window lays back more, and the rear lays forward more, but it would look stupid, if you want a mustang lower, then just lower it.
Old 12-25-2006, 07:44 PM
adtkart@aol.com
Can it be done. Of Course! I think anything with a roof can be chopped. It just depends on the amount of work you want to do, and results you want.
I wouldn't do it, but am sure someone has.
Aaron
Old 12-25-2006, 08:09 PM
bnewsom's Avatar
Last journal entry: more finished pics
When i read you post my response was the same -"WHY????". Those Mustangs have good proportions as they are. I saw a 67 or 68 chopped a few years back and it just looked out of proprtion. I would put my $'s and efforts into improving the stance and the rolling stock to set it apart. Just my 2 cents.
Bob
Old 12-25-2006, 09:32 PM
With a bunch of detailed goodies that car can look pretty sharp. I say leave it. But if you were to chop it, the windshield and back glass are the hard parts. The back glass is tempered and can not be cut. The side glass is as well, but I think it is flat on that car so you could cut new from safety plate.
Old 12-25-2006, 09:55 PM
I remember this 3.5 chopped '65 that was in hot rod quite a few years ago. I thought it looked good with the chop and lowering. But mustangs look nice as they are also. Its depends on what you want and like, not what others think. There will be a few people screaming if you cut up an old mustang anywhere. Do you want to look like other mustangs or do you want to be different?
Old 12-26-2006, 04:53 AM
adtkart@aol.com
With a coupe, like Brian said, glass will be an issue. I would make sure you have a glass EXPERT available. If it was a fastback, the windshield could be "adjusted" as well as the back glass, to use the originals. With a coupe, it is alot more complicated.
You might want to use one of the coputer programs to modify it and see what it looks like first. With the lines of a Mustang, chopping it will make it look more lke a train than a car.
Aaron
Old 12-26-2006, 08:30 AM
Arrowhead's Avatar
EFI Rules and Carbs Drool
Last wiki edit: The FREE T Bucket plans
Last journal entry: Sold Everything for a new project
Wiki Edits: 5
Not my taste, but here's another one. Good luck.
ID:	17139   Click image for larger version
Old 12-26-2006, 09:40 AM
You see, not that Chopped Mustang, I don't get. It is chopped quite a bit but all the rest of the body looks stock, it even has the emblems on the fenders. What is the "theme" of the car?
A near stock appearing car with a slight chop, that would look like it "belongs".
Go get yourself a book on factory "dream cars" or "Styling exercises" and see how a manufacturer "improves" the average car. Buick had a 63 Riv they called the "Silver Arrow", chopped about an inch and a half. Very nice looking car.
HK!!! Cost of top chop????? slider in wa Body - Exterior 11 11-03-2008 03:37 PM
TOP CHOP Bill Corum Body - Exterior 3 08-10-2008 10:29 AM
1966 mustang coupe for the wife big455 Hotrodders' Lounge 7 11-01-2003 11:11 AM
66 mustang coupe or is it a fastback? bradford074 Body - Exterior 5 10-04-2003 06:27 PM
66 Ford Mustang rear end gears 66StangBoy Transmission - Rearend 3 11-18-2002 06:22 PM
