Demon carburetor Free speech parts auctions.
Bid on used parts to help fight the frivolous lawsuit filed against us.
Click here for details.
Parts currently up for auction: Don Garlits engine emblem, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > Suspension - Brakes - Steering
  #16
Old 12-11-2002, 05:49 AM
Donbatman Donbatman is offline
Wink re: 66 Mustang front suspension upgrade
Used Stainless Steel Brakes kit for a 1968.Components are all first rate but $$$$$$.Installation was a breeze. Took about 2 hours to do.Did run in to small problems with the sizes of the hose fittings and ended up using the stock hoses.
For non-power w/ 4 piston caliper would suggest throwing out the master cylinder that come with the kit and getting one with a 3/4" or 13/16" bore to get some stopping power. 1" bore MC that comes with kit is a joke.The idiots @ SSB who spec'd this 1" size for the kit should be shot.
Will also need 15" rims for this conversion.
Other cool upgrades are poly bushings and a 1 1/8 Dia. sway bar.
My son also had new springs put in that lowered the front about 1 1/2".Maier Racing in Hayward Ca. has the parts and are first rate folks to deal with.
Ride is firm but is worth it for the killer stance the car has.
Old 12-16-2003, 09:05 AM
ewilson ewilson is offline
This is my first time on the forum.
I did install a 460 in a 66 mustang. I used the Heidt Mustang II front suspention. It was relatively easy to install, looks and works great. Gave me plenty of room for the 460.
Old 12-19-2003, 08:15 AM
Huskinhano Huskinhano is offline
I'm in a similar situation. I also own a 66 Mustang and want to do the same. I have a friend that road races a 66. He recommended Global West upper arms, 1" front bar, no rear bar and stock sprigs for the street.
As far as brakes, I'm going with Willwoods on stronger 72 spindles. Why the Wilwoods? They use 11.75 rotors and 4 piston calipers. I also have a Granada set up but consider the cost of buying the spindles, new rotors, rebuilt calipers, pads, new tie rods, tool rental (if needed) and front end alignment, I think you could spend more then the Wilwood kit and not have as good of braking system to boot. Down side of the Wilwoods, they'll widen the front track about an inch and you'll have to use 15" rims. The Wilwoods are also a bolt on, no need for alignment after your done!
BTW, as of now, I've done some simple upgrades like a 1" front bar, KYB's and export brace. These have made a huge difference.
Old 05-26-2006, 10:45 PM
unkamort unkamort is offline
after reserch question
Sorry to drag up this old thread, but after going through several searches of old posts I'll admit I'm confused. I had been told that by using Granada brake caliper brackets on Mustang 2 spindles I could make an easy conversion to 11" rotors. I even have part numbers (Wagner F9862,F9863) for the 11" brackets. No one that I have contacted has these part #'s available. When I go to the bone yard to find Granada spindles all they can come up with is strut type units, not "A" arms, on which the caliper brackets are cast rather than being bolt on items. Should I be looking for a V8 Mustang 2? OR what year Granada? The application in my case is for a Heights front cross member and tube A arm set up, using stock Mustang2 spindles from a '74 as memory serves.
Old 05-27-2006, 05:31 AM
KULTULZ's Avatar
KULTULZ KULTULZ is offline
aka Duke of URL
 KULTULZ's barnstar
-ROD AND CUSTOM MOTORSORTS-
-PN RC-129-
Easiest way out of it...
Old 05-27-2006, 10:05 AM
-PN RC-129-
Thank you Sir! That may be the answer.
Old 05-27-2006, 02:09 PM
xntrik's Avatar
xntrik xntrik is offline
Save a horse, Ride a Cowboy.
Originally Posted by deuce_454
the first car i built was a 65 mustang. there are several mods that can be made to the stang without braking the bank. the first one is the lowering of the upper controll arms. where you redrill the attatching holes in the shock tower.
make a template in steel or cardboard with two holes that fit the upper controllarm bolts, then make two small holes in the template that are offset 1 inch downward and 1/8 inch rearward in relation to the car. then mark the pinholes with a center punch on your shocktowers (be sure to flip the template on the opposite side of the car so the holes are ofset 1 inch down and 1/8 inch rearwards on both sides of the automobile)
then drill the holes (i think they are 7/16) and re-attach the upper controll arms and you have a suspension geometry that is upgraded to Shelby GT 350 spec. and it is absolutely free..
its the best upgrade ive ever made to make a car handle better, now it actually goes straight on the highway, and it doesnt understeer when you push it.
While you are at disassembling the front end you could put in some polyurethan bushings, they also help emensly
and lastly here is a link with detailed instructions on how to swap in a mid 80's GM j-car rack and pinion, also without buying expensive kits and so on.
<a href="http://home.pacbell.net/ssixto/automotive/R&P/HowTo.html" target="_blank">http://home.pacbell.net/ssixto/automotive/R&P/HowTo.html</a>
As DUKE indicated in # 6, If you research carefully you might discover that there are other modifications done by Shelby to the 65-66 GT 350 steering. The GT 350 also used a longer pitman arm and idler arm to quicken the steering and alter the bumpsteer.
Rebuilding the front and rear suspensions with urethane bushings makes the car handle very well compared to a stock rubber vehicle, and the 15/16 anti-roll bar from the Granada makes a remarkable difference.
65 to 73 Mustangs are just Granadas in disguise.
If you want a good power steering unit, try the 71-3 Mustang Saginaw unit.
I prefer the 70s Granada conversions unless money is no object.
Old 09-18-2006, 09:56 AM
66-351 66-351 is offline
I've read about the control arm lowering, or "Shelby drop". I've also helped a buddy of mine do it on his 65. The drill bit you need to do this with is a 17/32 not a 7/16. The wrong bit or wrong placement could be disasterous. Always make sure your template is dead on it and check two or maybe three times before you drill.
Old 01-01-2007, 02:47 PM
64TBOLT 64TBOLT is offline
MII suspension in a 63 Falcon
does anyone have any pics,writeups about using the stock MII front suspension in a 63 Falcon.I emailed one person on here but the email came back.I'm not buying a kit cause i allready have the MII front end. Thakks
Old 01-01-2007, 06:59 PM
xntrik's Avatar
Naw, it is not that critical. Most cars are NOT built "square enough" that an 1/8 here or there makes much difference. Most Mustangs have shock towers collapsed quite a bit anyway. It is almost invisible to the naked eye.
You just haven't seen any Mustang/Falcon unibodies on a "squared frame machine". Some are really scary after 40 years of abuse.
Old 01-01-2007, 07:03 PM
xntrik's Avatar
You might cruise the Mustang & Fords website and see if you can find the article Wayne Cook did putting a kit front end in a Comet. Others, Mustang Illustrated, Mustang Monthly might have an article about the Mustang swap.
Old 01-02-2007, 04:32 AM
Originally Posted by clouddancer@attbi.com
I have a stock MII crossmember in my 61 Pro street Falcon project. Also I'm getting ready to do the MII swap on my daily driver Falcon. If you want info on how to use the stock MII crossmember contact me at &lt;clouddancer@attbi.com&gt;
The best 60's Ford kits are made by Rod & Custom motorsports in S.C. here is the link
&lt;http://www.rcmotorsports.net/&gt; They've even got a step by step install on the web page.
The best reason for going the MII swap is you get disc brakes in either 9" or 11" or even SS brakes 13", at the same time you get rack & pinion steering and a stiffer front end that works, a side benefit is no shock towers, one point to be made is with "W","C","FE",or 429/460 engines you must use the oil pan for the late model Mustang.
Papabird
anyone know how to get hole of this guy.??
i have the front end!!! NO KIT
Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
