Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 66 mustang rack and pinion
Old 06-24-2004, 09:24 PM
EBlack36's Avatar
EBlack36 EBlack36 is offline
Rebuilt Excitment
Randalls Rack uses the GM J car center pull rack and a corvette pump. The price with pump and bracket is around 1,500.00, about a grand less than the TCP (Chris Alston Chassisworks) unit. This is the unit I have decided on for the Cougar when I get the money saved up, It uses the original Mustang, or in your case Granada tie rod ends. This is a completely bolt in kit with the exception that you will need to modify you column, the parts you need to do that even come with it. For about the same money you can get the manual kit from flamming river which includes their steering column, however I understand from another forum that I belong to that they have some issues with bump steer. Good luck.
