66 mustang rear end - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-18-2006, 05:45 PM
66 mustang rear end
Im looking for replacement rear end.. 8.8 what other year and cars will fit in it..thanks for the help
Old 02-18-2006, 05:53 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
For a direct bolt in, only the 80 Mercury Monarch (and a FEW Granadas) with the delux package that looks like a Versailles had 8.8 on leaf springs 2.47 gear with big drum brakes and is a direct bolt in, except that you will need 67 Mustang lower spring pads and u-bolts since the tubes are 3 inches in diameter, not small and tapered like the old Mustang. The overall wheel to wheel width is the same 57 1/2 and the spring pad width and pinion angle are the same. Get the driveshaft too, since the rear yoke might be different. Yes, the 66 Mustang and Granada cars are the same wheel base so the driveshaft should fit..
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
4x4 12 bolt rear end same as 2wd rear end??? Ed ke6bnl Transmission - Rearend 2 05-24-2008 02:25 PM
ford rear end indentifer 40blackie Transmission - Rearend 15 01-23-2006 07:39 PM
Ford 9" rear end vs stock 89 chevy truck rear end jimmy p Transmission - Rearend 2 12-07-2005 03:28 AM
Lowering a 66 stang with a Versailles rear end Sharris Suspension - Brakes - Steering 4 09-15-2002 03:58 AM
