Thread Tools Search this Thread share on Facebook
  #1
Old 02-04-2009, 12:10 AM
66Moostang's Avatar
66Moostang 66Moostang is offline
'66 Mustang Tachometer
I want a tachometer on my '66 Mustang but dont want the $400 rally-pac... I found a '65 rally-pac tach (just the tach, not the clock) and wanted to know if it would work good and accurately on my stock 6-cyl '66 Mustang. If not, is there another tach (perhaps aftermarket) that would be accurate on this kind of setup?
Any help at all is greatly appreciated!!
Register now (free) or login to remove ads
Old 02-04-2009, 06:45 AM
woodz428's Avatar
woodz428 woodz428 is offline
Troll Hunter
I would have to look at a schematic for the tach, but am pretty certain that some modification in the circuitry would have to be made for it to work with the 6.....IF it came from a V8 car. I think you could get one on a 6, but I'm not sure. If you have an original Rally Pak, even without the clock, it is probably valuable enough to allow you to buy a more accurate modern electronic Tach( the original ones are electronic too). Most aftermarket tachs are designed to operate with 4-6-8 and maybe more and less cylinders, usually with a switch or designated wiring.
Old 02-04-2009, 07:19 AM
1BAD80's Avatar
1BAD80 1BAD80 is offline
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
ditto with woods.
Autometer has a bunch of them, plus most have a size that will install in the old space.
Tacks of todays standards usually will run from 1 cyl to 12, & change color & grafts, shift lights, digital has come a long ways.
Most hook up to the positive side of the coil , 1 for ground ,1 for lights.
Very easy to hook up.
The hardest part will be choosing what one to buy.
Do a Google search to find all that is on the market with prices.
The cheap proform is not the best, mine is on a bone-shelf.
Remember you get what you pay for.
Luv the smell of NITRO in the morning.
Old 03-10-2009, 03:47 PM
65 FB 65 FB is offline
Hi 66 Moostang
Your tach depends on weather it is a 6 or 8 cyl
What rpm does it go up to? if its 8000rpm its an 8 cyl and wont work.
If its 8 cyl mine has just packed up and I would be interested in buying
Thanks Mark
Old 03-10-2009, 04:35 PM
red65mustang red65mustang is offline
they are available for a six cylinder but (cough cough) the price is pretty steep...
http://www.mustangsunlimited.com/it...catkey=EMUSTANG
I made one once, used a SunPro mini tach,,,for me it was to small a dial sweep to be good for almost anything...
not as pretty but here's my current version of a "rally pack look"
(someday I might get around to making the saddle bridge part again)
just a instrument "cup" on the vac guage for a finished look and a (CRS!!!) solid steel type geared type hose clamp painted to match the column,,,wires and vac hose routed in the "U" for the column...
Name:  tach and vac.JPG
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "'66 Mustang Tachometer"
ThreadThread StarterForumRepliesLast Post
66 Mustang won't start, no lights, no instruments, batt good...danbeckElectrical301-25-2009 08:52 AM
66 Mustang parts swap66MoostangSuspension - Brakes - Steering1012-15-2008 02:09 PM
66 Mustang front end changentx_gearheadSuspension - Brakes - Steering1511-23-2008 10:45 PM
66 Mustang front brakes66-351Suspension - Brakes - Steering309-18-2006 07:16 PM
66 Mustang fastback quarter glassoink513Body - Exterior707-08-2004 04:31 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
