Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 66 Nova door bushing replacement
Old 06-26-2012, 07:45 PM
deadbodyman's Avatar
deadbodyman deadbodyman is offline
Wiki Edits: 11
It should be easier than a truck because you can take the hinge out and do all the cutting and pounding on a bench...most trucks (GM anyways) are welded on and cant be removed or adjustedand getting those factory pins out can be a PITA I usually cut the pin in half with a small cut off wheel ...
Its been a while but I believe if you remove the inner skirt you can get at the (hinge to body) bolts fairly ez and dont have to remove the fender...
