-   -   66 nova ignition lock ring.... (http://www.hotrodders.com/forum/66-nova-ignition-lock-ring-61756.html)
sc2dave 04-24-2005 01:38 AM
my ignition switch just hangs. where can i get a lock ring that keeps the switch fastened to the dash?
1Fast65Elky 04-24-2005 09:34 PM
yes, i seen them on ebay for 10 bux......what i did i Im a cheap person...i just found a big brass nut (what i had use any type if it fits) that screwed on the ignition. put the switch thru screwed the nut on and worked like a charm. :thumbup: ill go look for the link on ebay and come back to edit it in.
-here ya go :thumbup: http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW ......ignition nut is another term.
MI2600 04-24-2005 09:51 PM
There used to be a guy on Ebay who sold a tool that had three pins to remove/install those rings. It sure saves using some water pump pliers and gouging the heck of the ring. You might try a search under Tools.
