66 nova ignition lock ring.... - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-24-2005, 01:38 AM
my ignition switch just hangs. where can i get a lock ring that keeps the switch fastened to the dash?
Old 04-24-2005, 09:34 PM
1Fast65Elky's Avatar
Left Nut, Right Nut....Squish!
yes, i seen them on ebay for 10 bux......what i did i Im a cheap person...i just found a big brass nut (what i had use any type if it fits) that screwed on the ignition. put the switch thru screwed the nut on and worked like a charm. ill go look for the link on ebay and come back to edit it in.
-here ya go http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW ......ignition nut is another term.
Old 04-24-2005, 09:51 PM
MI2600's Avatar
Member# 3287
There used to be a guy on Ebay who sold a tool that had three pins to remove/install those rings. It sure saves using some water pump pliers and gouging the heck of the ring. You might try a search under Tools.
Ignition system info................ poncho62 Electrical 18 10-11-2008 10:10 PM
I want to install an underdash ignition kill switch in my 67 nova...can you help? batman09 Electrical 40 05-15-2005 09:47 PM
ignition lock help needed stea Suspension - Brakes - Steering 1 04-16-2005 10:31 AM
Shock tower removal on 66 Nova, help! frankenvette Suspension - Brakes - Steering 2 07-06-2004 05:48 AM
how to remove ignition lock cylinder on a 1981 trans am stoney 81ta Electrical 9 12-13-2003 07:30 AM
