Thread Tools Search this Thread share on Facebook
  #1
Old 01-27-2012, 09:18 PM
Toddtex Toddtex is offline
66 Nova tail/brake light nightmare
Purchased 66 Nova at Mecum KC. 350ci, 5.7L. Originally a 6 cyl. Don't know history of wiring. Head lights and front blinkers work fine. When car arrived, tail lights worked, but no back up or brake lights. Now no rear lights work. Checked voltage, only getting 2 volts at tail lights. Replaced light switch. Checked fuses - fine. Fuel gauge doesn't work properly, always registers full. No radio. While tapping brake pedal, noticed that when I tap the pedal the dash lights come on for duration of the pedal. Any suggestions from electrical pros appreciated! Toddtex
Register now (free) or login to remove ads
Old 01-27-2012, 09:54 PM
tinfoot tinfoot is offline
tinfoot
did the resto shop replace the entire wire harness.or just clean&reinstall?
Old 01-27-2012, 10:33 PM
Based on the condition or the wires & harnesses, these are original/worn wires. No new harnesses were used. Do you think a new harness would fix the problem?
Old 01-28-2012, 06:17 AM
EOD Guy's Avatar
EOD Guy EOD Guy is offline
Yes a new harness will fix your problem. Hard to tell with out seeing it etc...... You'll have to start at the fuse box and work your way to the rear checking every connectione , wire etc..... after chasing demons for a few years on mine I decided to do the rewire....... best thing I ever did for the old girl, really was very easy and took two weekend. Now everything works properly and no more dim headlights etc....
I used Painless, others will chime in with what they used, but really boils down with budget, time and expertize.
Old 01-29-2012, 06:35 PM
Lucked out!
Thanks for the responses. After reading many posts, we decided to focus on ensuring improved engine grounds. Long story short, once we were properly grounded, the tail lights, turn signals and brake lights now work great. Appreciate the responses. Toddtex
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "66 Nova tail/brake light nightmare"
ThreadThread StarterForumRepliesLast Post
Brake/Tail Light wiring1F9O4R7DElectrical1608-24-2010 12:50 PM
how do i fix nova tail light area?andy_s273Body - Exterior207-01-2009 08:10 AM
Tail Light Light-Bulb65cometElectrical1309-28-2008 11:10 AM
third tail light help49fordp/uBody - Exterior501-10-2008 07:24 PM
brake light, turn signal, tail lamp problemworknprogress72Electrical601-06-2006 12:20 AM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
