66 six cylinder mustang 9" rear end axle spline? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-12-2012, 11:41 PM
427feracer's Avatar
First On Race Day
I have a 66question mustang that came with a six cylinder engine. I need to know some specifics about the rear end I know it is a nine inch rear end open diff and the axles are four lug bolt pattern but, I was wanting to know what the splines would be on the axle shafts and I was hoping that instead of taking them out to findd out someone might know???? I do know they have a 28 spline shaft and a 31?? Please let me know im thirsty for some knowledge! Thank you.
Old 02-12-2012, 11:44 PM
Canzus's Avatar
a red wool sock on his dinger
Its probably an 8", not a 9", so the axles will be 28 spline...
Old 02-13-2012, 04:17 AM
Wiki Edits: 31
It's not a 9". it's a 7.25" ( bolt on rear cover ) or 8"( drop out pumpkin). I think there 28 spline if 8". the 7.25" is only strong enough for a stock 6cyl which is all they came behind.. '65-'66 were 2 years that 6cyls had the 4 lug 8". all other years had 7.25" 4 lug and some of the '66's have 7.25" as well
Rear axle spring on a "T" mark1demon Suspension - Brakes - Steering 4 07-16-2010 07:21 PM
1969 Mustang Rear Axle Vent CandyRed69 Transmission - Rearend 4 04-03-2010 08:12 PM
Change Ford 9" - 28 spline to 31 spline fredbaker Transmission - Rearend 5 09-27-2009 04:12 PM
"roaring" noise in the rear end of my 1998 mustang 223Mustang Transmission - Rearend 1 05-02-2009 11:27 AM
"roaring" noise in the rear end of my 1998 mustang oldsgeek Transmission - Rearend 10 12-26-2004 08:14 PM
