66 T-Bird - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Hotrodders' Lounge> Introduce Yourself
Old 03-13-2008, 03:49 PM
jayjassyjania's Avatar
Prince62
Last journal entry: 66-T-Bird
66 T-Bird
How can I replace the rear main seal on my 66-t-bird 390 without taking the engine back out of the car?
I'm restoring a 66-Ford T-Bird 390 .030 Over piston & rings, .010 crank shaft, rod bearing and main bearings. Competition Cam K-Kits 484 lift/ rpm 1200-5200. Block was restored, and rebuilt transmission.
Also have 73-Ford F-100 small block 302 .030 over, aluminum
heads, Competition Cam K-Kits 512 lift/2000-6000rpm. AED 750 Double Pumper Holey Carb, Seal Power High -volume Oil pump and headers.
Both of these machines run like a dream.
Last edited by jayjassyjania; 03-14-2008 at 01:39 PM. Reason: Not sure how to get my question recognize!
Old 03-13-2008, 03:58 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Welcome, we are glad to have you with us here at Hotrodders.
Old 03-15-2008, 02:52 PM
Job~Rated's Avatar
Artful Dodger
Last journal entry: From behind
Welcome!
Post your question in the tech section on the main board.
Old 03-15-2008, 10:27 PM
life is a temporary assignment
Welcome aboard!!!
what is the fastest (factory) car you have ever driven? badknuckles Hotrodders' Lounge 320 12-09-2011 02:32 AM
Trans Am bird steel dragon Hot Rod Art 2 06-05-2007 08:47 PM
Street Legal TV to Broadcast Video from NMCA Super Bowl Event at Route 66 nmrajames Hotrodders' Lounge 0 07-26-2006 10:53 PM
66 el camino 66 c-10 rear end swap? Echofive Transmission - Rearend 0 01-30-2004 11:47 PM
66 GTO mania in the auto trader bullheimer Hotrodders' Lounge 2 01-26-2004 06:12 PM
