66 t bird 428 heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-28-2012, 06:48 PM
66 t bird 428 heads
Can you use 390 heads on a 428 Engine in a stock 1966 Ford Thunderbird? What is the difference, are they the same heads just different crank and rods ?
Old 04-28-2012, 10:22 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
I don't know Fords, why don't you just go to say JEG's or Summit, look up a pair of heads and see it they're listed for both motors?
Semper Fi
Old 04-29-2012, 08:23 AM
Last journal entry: My Last Hot Rod
yes you can use them
only difference is valve sizes
Old 04-29-2012, 09:00 AM
There are several 390 castings. All of them will physically "fit" the 428 (bolt patterns all the same). You should verify chamber volume as well, before using them. Compression could be too high for "pump gas". Smaller valves will improve response and low-speed power at the expense of higher-rev performance.
Bore size and stroke are different between 390 and 428. 4 1/16 x 3 3/4 vs. 4 1/8 x 4" (roughly). Rods are the same(dimensions).
Jim
428 heads for a 390 Fe Crazy_John69 Engine 9 11-08-2011 06:21 PM
T-Bird 390 or 428? Zooie Engine 4 06-16-2009 11:51 AM
What's a 1966 428 FE out of a Ford T-Bird Worth? joedaddy Engine 37 08-22-2008 04:43 PM
428 pontiac heads 72 Z28 Engine 5 12-04-2003 08:19 AM
ford 428 heads rahlert Engine 5 09-08-2003 10:08 PM
