66 truck , 87 sub swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-15-2007, 01:14 PM
badriand's Avatar
I sent F&J a message but thought i would see if any others had any says also. I have a 66 chevy truck and found a 87 suburban can i use the front upper and lower arms etc off this to put under the 66 and also use the master cylinder including booster. Possibly the power steering setup also? Thanks in advance.
Old 05-15-2007, 02:02 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
Everything you need to upgrade the brakes and the steering are there.
But, as one poster had mentioned---check the frame horn closely for cracks,
Steal all the steering links too. Shorten steering shaft.
Bryan
Old 05-15-2007, 02:08 PM
badriand's Avatar
Ok i'm going to get retarted here, what is a frame horn?
Old 05-15-2007, 02:56 PM
Bryan59EC's Avatar
The portion of the frame that extends past the front crossmember.
The steering box is attatched to to the 'horn'
Bumper and core support are attatched to the 'horns'
Bryan
Old 05-15-2007, 03:31 PM
badriand's Avatar
Makes sense, thanks .
66 ford truck twin i beam lowering tech igotachevyor2 Suspension - Brakes - Steering 15 12-16-2011 08:45 AM
55 chevy truck frame swap john sekulich Introduce Yourself 1 02-20-2007 08:15 PM
66 Chevy truck with newer engine questions? HemmiGremmie General Rodding Tech 4 07-23-2006 07:49 PM
66 283 auto / 67 283 swap Question FasterPastor Engine 1 11-05-2002 01:48 PM
please need help w/ 66 stang brake swap ping001 Suspension - Brakes - Steering 1 03-26-2002 10:29 PM
