66 vette clutch pedal push rod? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-15-2009, 05:44 PM
Hi,
Can anyone tell me if there is a difference in length in clutch pedal push rode in a 66 vette if you are using a 327 vs 427 engine? If so can any on tell me the proper length for 427 clutch pedal push rod?
Thanks
Old 11-16-2009, 11:14 AM
Cant say about the length, but the 427 rod is different part number than the 327Vette rod. The 427Vette rod is the same number as a full size car 327, 3859863
Old 11-16-2009, 03:32 PM
artsvettes's Avatar
8 37/64 inches the 327 is longer
master cylinder interchange runn141 Suspension - Brakes - Steering 7 05-03-2009 05:15 AM
Brake Push Rod Adjustment jor Suspension - Brakes - Steering 4 12-05-2007 05:23 PM
push rod prices chevypunk Engine 6 04-18-2003 03:55 PM
bent push rod el Engine 2 03-13-2003 06:11 PM
Chipped exhaust push rod tip jpd37 Engine 4 02-21-2003 01:03 PM
