66783 Proform Rocker Stud Puller and Tap guide? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-22-2010, 12:32 PM
Silverback's Avatar
Boost Retard
How does this thing work/how do you use it? It looks like a piece of bar stock with 2 holes drilled in it and a loose fitting pin, I can't really see how it would either help pull a stud or tap a stud boss... what am I missing?
http://proformparts.com/product-exec...category_id/67
Old 12-22-2010, 12:36 PM
King of my Man-cave.
I have one like it from Goodson. You use it to tighten down against when using a nut and washers to pull studs out, then you use it as a guide when tapping the holes for screw-in studs. The pin fits snugly in the holes the studs are pulled out of.
tom
Old 12-22-2010, 02:04 PM
Silverback's Avatar
Boost Retard
Is it worth the effort?
I usually use stack a few exhaust valve rotators on there and it gives me a pretty much frictionless surface to turn the nut against, and I don't know that that would guide the tap accurately enough (I would normally just set it up on a drill press or mill to run the tap, if you're using studs with a hex on them you need to mill down the bosses anyway).
If it gives you accurate straight threads without the setup involved in getting the angle right on a mill or drill press, it might be worth the time saved...
The reason I'm looking for stud pullers is that I have a set of heads that have 2, maybe more monkeyed up studs that I don't believe I'll be able to pull by threading a nut on them, I don't know that I can even get the existing nut off of one of them, and I don't really know yet how I'm going to get them out.
Old 12-22-2010, 02:24 PM
Banned
you can cut the top of the stud off and retap the lower section to fit a nut on, you can also try drilling them out with a bit that is slightly smaller than the stud, you better have it braced really well and perfectly centered and aligned though.
Old 12-22-2010, 02:55 PM
If I have a stud that's not going to pull out, I cut it off near flush with the guide boss, grind it until it is flush and square with the guide boss, a drill it out with progressively bigger drill bits until it spins out.
tom
Old 12-22-2010, 03:27 PM
Silverback's Avatar
Boost Retard
Um, those studs are pretty hard, what kind of die are you using to cut the thread with? I was also under the impression that it is not a normal 3/8" fine thread, it's a finer pitch (I remember trying to find a matching nut and wasn't able to)
Old 12-22-2010, 08:49 PM
They are hardened only on the outside. You can use a cut-off disc in a die grinder. Any die will cut extra threads on the stud.
The threads are 3/8x24. I use connecting rod nuts.
tom
Head stud puller jake_arcticcat Garage - Tools 3 09-18-2008 10:07 PM
replacing pressed rocker stud with threaded stud DHMag Engine 16 09-06-2007 04:57 PM
How well do the stud puller and tap guide tools work? Dubz Engine 2 12-14-2004 03:02 PM
rocker stud to rocker clearance 85406 Engine 2 07-16-2004 09:25 PM
proform stud girdle leo Renner Engine 2 10-29-2003 08:03 PM
