67 327 275hp "mm code" engine - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-05-2009, 09:06 AM
streetrodderbn's Avatar
Certifiable Streetrodder
Is anyone aware of a manufacturer for forged dish pistons for a 327 that don't have the 1/16 rings? I just got a great donor block and crank/rods, and want to build a mild blower engine for the street ,using my b+m 162 blower. The only listing I can find is for a 5.8 in. rod, I really want to use the stock rods (reconditioned with with arp bolts.)
Old 10-05-2009, 09:47 AM
DoubleVision's Avatar
Is this engine a small journal? if so I wouldn`t reuse the stock rods no matter what bolts they have. Small journal rods aren`t known to be very stout.
I haven`t had much luck either on a piston your looking for. But keep in mind, it also depends on what cc head you plan to use, if you use a 76cc head you can run a flat top piston and have the compression ratio low enough for a blower. I`ve seen aftermarket heads with bigger chambers that would fit the bill nicely.
Old 10-05-2009, 01:36 PM
yes this is a small journal engine, I'm not planning on a wild combo, this is for a streetrod. probably never see excess of 6psi boost, and 4500 rpm.
327 chevy engine 1964 high torque Swanie Engine 4 08-23-2016 05:04 PM
head selection for a '67 327 jafroyd Engine 4 06-01-2009 09:07 AM
327 truck engine ??? richall Engine 5 01-04-2008 01:18 PM
sick 327 engine 67burb Engine 1 10-16-2002 03:50 PM
327 engine rebuild small journal Impala5967 Engine 4 01-04-2002 11:01 PM
