67-68 Ford Mustang Tilt Rebuild Kit or Column needed - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-11-2010, 02:01 PM
lconnell's Avatar
Dan & Shirley's 29 Ford
I have a 29 Ford street rod that has been completed but I still need to redo the tilt as it will not lock in any position but full up. With the angle of the column this still looks OK. I have been looking for these parts for some years now. This columns are hard to find so are too costly to try as it may also be worn out when I get it apart.
Please help. (My car is listed in the photo Gallery "Dan and Shirley's 29 Ford"
Thanks,
Dan
Old 12-12-2010, 06:34 AM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Seems like you can get or have that mustang column re-built, Have you check or thought about ididit or flaming river products or maybe they could do a re-build on it also or point you in the direction you need.
Have you tried to google it and see whats out there ?
Cole
Old 12-12-2010, 10:05 PM
lconnell's Avatar
29 ford needs Mustang Tilt Repair Kit
Hey, thanks for the comments. I have been looking for a kit so I can rebuild the locking mech. I have found used columns I could salavage some parts from on eBey. ($400.00 to 1300.00) I had to modify the column when I installed the steering. So the after market Flaming River / other after market columns are costly and will have to be modified to be able for me to install with out getting into a big trashing on a finished car.
Thanks again at least some one read my note.
Dan Connell
Old 12-15-2010, 12:21 AM
327NUT's Avatar
Check the local bone yards ...$400-$1300??? for a donor column? You can buy a brand new Ididit tilt column to fit your car for about $325 on ebay. I'd do some shopping.
Old 12-21-2010, 10:07 PM
68 Tilt
There are no rebuild kits available for this column. There are only a few parts available either. (Upper Bearing, lower bearing, TS switch). There are one or two people in the country who specialize in rebuilding these columns. They are not cheap however. IOt requires specialized tools that are not available either. As you have seen on e-bay used columns, even crappy one go for big bucks. I am currently rebuilding one for my 68 Mustang so I feel your pain. At this point your best bet might be an aftermarket column or a later model with more parts availability. Do you have a 67 solid shaft column or the 68 collapsable one? If you decide to go with a different column, let me know I might need some parts off your current one which could help offset the costs of a new column.
Old 12-21-2010, 10:23 PM
lconnell's Avatar
67 -68 Steering Column Repair
Ok! thanks for your input. I will keep you in mind if I change out the current column. My mustang column is OK except for the column will not latch in any position except full up. The machine shop that did the rework (shorting and 3/4 DD) on the end of the shaft lost a part in the latching on the right side that holds it in the position. The wheel lays over to the left side when it is positioned in any of the other that full up lock.I modified the column when I installed it with a molded 6" drop and a mounting plate to securer it to the floor. It is a 67 Column.
Thanks again I will let you know if I pull it out.
Dan
Old 01-09-2011, 05:40 AM
New Member
Thanks,
Dan
Where are the photos? Provide me the links if they are already posted...
Old 01-09-2011, 01:01 PM
lconnell's Avatar
67 Mustang Tilt in a 29 Ford Street Rod
Click on my name and itwill take you to my photo gallery.
Old 02-09-2011, 10:08 PM
Tilt
What type tilt do you have on it? The pic is too small to tell.
Old 02-10-2011, 08:01 AM
lconnell's Avatar
67 Mustang / Cougar tilt Column repir kit needed
The column is a 67 Mustang / Cougar tilt. I molded a 6" drop into the column.
Old 02-10-2011, 08:26 AM
lconnell's Avatar
Added Construction Photo
Here is a beeter photo of the steering column.
Old 02-11-2011, 02:54 PM
Tilt repairs
I don't see your new photo, it appartently didn't upload. I have some sources for the tilt parts. Do you know what piece is missing?
Old 02-12-2011, 01:14 AM
hp246's Avatar
I second give IDIDIT a call. They are manufacturing new columns to fit the Mustangs. They might have a source for these parts or be able to point you in the right directions. They are a family business and good folks to deal with.
Old 02-16-2011, 07:01 PM
Ididit columns
The Ididit columns are complete new designs based. None of the parts they produce will be of any use in the 67 Mustang column. They would make a nice alternative if you wanted to swap out the column altogether.
Old 02-16-2011, 08:33 PM
hp246's Avatar
What you say is true, but these folks are really customer oriented. If anyone can source these parts, it would be them.
what is the fastest (factory) car you have ever driven? badknuckles Hotrodders' Lounge 320 12-09-2011 01:32 AM
Tilt column rebuild johns37ford Suspension - Brakes - Steering 2 11-26-2006 07:56 AM
Ford C5 Rebuild Advice Needed k2mooch Transmission - Rearend 0 01-13-2004 07:55 AM
9 inch ford rearend for my 67 mustang cgainey Hotrodders' Lounge 1 01-27-2003 11:16 AM
Whatever happend to these guys? hot_rod_kid Hotrodders' Lounge 20 12-17-2002 09:20 AM
