67/72 c10 make a lb into sb a need advice - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-04-2012, 02:45 PM
i have 69 gmc 1/2 ton custom cab leaf spring lb i want to make it a sb body/frame are in grate shape and rust free. i have a bed. anybody done one?
Old 09-04-2012, 05:02 PM
I have shortened plenty of heavy truck chassis but those are a differrnt animal, when ever i get a call for a smaller truck like an f450 or similar truck i cut behind the cab and remove the length of chassis needed and bring them together weld and then i get a peice of channel that fit snug inside the chassis drill that and the chassis and bolt it together. Then the usual drive shaft fuel line etc.. i have done countless in this manner and never had had one failure i have done this with smaller dump trucks, tow trucks, car haulers custom flatbeds. This was a condensed version of how i do it. Theres alot more to it but i think you get the general idea.
Old 09-04-2012, 07:48 PM
Wiki Edits: 31
It has been done. There is a spot in the middle of the bed area that gets cut and shortened. It's where the factory put the SB/LB difference.
Experienced painters advice please! Advice on painting a frame El Campo Hotrodding Basics 25 03-13-2012 04:21 PM
advice how to make a chrome trim strip? Adrenalin540 Body - Exterior 12 03-05-2012 11:16 AM
Value of my 85 C10 85c10SS Hotrodders' Lounge 1 11-06-2010 06:15 PM
78 c10 VicentJackle Introduce Yourself 3 12-30-2005 11:14 PM
