67 C-10 Chevy Brakes question - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-07-2011, 12:15 PM
i bought a 67 C-10 with a 396 in it at an auction last month. I finally got time to take it apart this weekend so i can find out what it all had in it. It has disk brakes on the front, but i have been told disk brakes started showing up on 73+ chevys. So im assuming that my truck has 73 or newer spindles off a chevy. Does anybody know if my facts/ hypothesis are correct or if you have any more info that would be great cause i dont wanna spend 2grand on brakes and have them not fit. Thanks guys and gals if your out there!
Old 02-07-2011, 12:39 PM
How many studs are on the rotors you have now 5 or 6 disc brakes were optional starting in 1970 but earlier trucks such as the Camper Special had 6 lug discs.
Old 02-07-2011, 12:51 PM
Wiki Edits: 31
yep. '70-'71 had optional disc brakes. '72 was standard I think. I know the rotors on my dad's '72 have a machined groove in them. don't know if that tells you anything... a look at LMC should be able to match you up with what you have.. '73-'87 crossmembers do fit so you may very well have a '73-'87 setup
Old 02-07-2011, 09:51 PM
SSedan64's Avatar
I think in 71 Disc & 5-lug was standard, mine has a DiscBrake sticker on the Tailgate.
Old 02-19-2011, 09:59 PM
Disc only in '71, no drums except on the rear. Power assist was optional.
No brakes on my 55 chevy tri5ernie Suspension - Brakes - Steering 2 08-14-2006 10:38 AM
51 chevy brakes mondo23 Suspension - Brakes - Steering 3 07-23-2006 03:11 PM
Bendix Brakes Question flatford39 Suspension - Brakes - Steering 1 03-19-2006 01:08 PM
60 Chevy Brakes pearldrumbum Suspension - Brakes - Steering 1 03-09-2006 05:48 PM
Question about brakes. Bluepen Suspension - Brakes - Steering 1 01-26-2005 02:37 PM
