Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 67 C-10 with some front end problems
Old 10-01-2012, 10:17 AM
tony@roadstershop tony@roadstershop is offline
From 63-87, the front crossmember of these trucks were all nearly identical with the only difference being essentially bolt pattern, ball joints and tie rod ends. If you want to replace the whole crossmember and want to go to a five lug for better wheel selection, head to the local wrecking yard and buy the front crossmember from a 73-87 and get the rear axle as well.... this will essentially bolt right up under yours........
