-   -   67 C-10 with some front end problems (http://www.hotrodders.com/forum/67-c-10-some-front-end-problems-222431.html)
stempy4930 08-01-2012 03:04 PM
have a 67 c10 with some front end issues,curious how hard it would to put in a ifs to resolve most of these.truck does not have power steering.most of these kits say no welding but also says to cut frame for ifs?any help much appreciated
Deuce 08-01-2012 04:12 PM
Every 67 C10 I have ever seen has a IFS ... from the factory.
Heavier duty trucks of that year do have a straight axle.
bigdog7373 08-01-2012 04:16 PM
Yep c10 has ifs stock. Unless you have a k10?
C = 2wd
K = 4wd
stempy4930 08-01-2012 07:03 PM
guess i need to clarify,how hard would it be to take everything out and put in a heidt ifs?
Deuce 08-01-2012 07:25 PM
WHY ??
The stock IFS is a good design, study enough for the trucks weight and parts are easily accessible. It would cost 3 or 4 times the $$$ to install A Heidis VS a stock rebuild.
speedydeedy 08-01-2012 10:22 PM
IFS swap
It is very cheap and easy to swap in a 1973 to 1985 Chevy 1/2 ton 5 lug front end.The used parts are plentiful and cheap.I put a 1981 front cross member in a 1965 C10 with no problem.Your truck does have IFS but it has 6 lugs and no power disc brakes or steering.With the right donor truck you can make the swap for whatever it costs for the donor truck and a few parts that might need replacing like bushings unless the donor truck is in good shape.You can drop the truck with drop spindles that are readily available for the newer truck.I am not trying to make money,this is free info. If you want to know more details just ask.
stempy4930 09-20-2012 04:28 PM
found out most of front end is junk,only thing ok is center link.pass lower control arm is bent.wanting to upgrade to disc brakes.have replacement tie rods,what else will i need and from what trucks can i get the parts
tony@roadstershop 10-01-2012 11:17 AM
From 63-87, the front crossmember of these trucks were all nearly identical with the only difference being essentially bolt pattern, ball joints and tie rod ends. If you want to replace the whole crossmember and want to go to a five lug for better wheel selection, head to the local wrecking yard and buy the front crossmember from a 73-87 and get the rear axle as well.... this will essentially bolt right up under yours........
