67 C-10 with some front end problems
have a 67 c10 with some front end issues,curious how hard it would to put in a ifs to resolve most of these.truck does not have power steering.most of these kits say no welding but also says to cut frame for ifs?any help much appreciated
Every 67 C10 I have ever seen has a IFS ... from the factory.
Heavier duty trucks of that year do have a straight axle. .
"I won't be wronged . I won't be insulted, and I won't be laid a hand on. " |
guess i need to clarify,how hard would it be to take everything out and put in a heidt ifs?
WHY ??
The stock IFS is a good design, study enough for the trucks weight and parts are easily accessible. It would cost 3 or 4 times the $$$ to install A Heidis VS a stock rebuild. .
| The Following User Says Thank You to Deuce For This Useful Post: | ||
stempy4930 (08-01-2012) | ||
IFS swap
It is very cheap and easy to swap in a 1973 to 1985 Chevy 1/2 ton 5 lug front end.The used parts are plentiful and cheap.I put a 1981 front cross member in a 1965 C10 with no problem.Your truck does have IFS but it has 6 lugs and no power disc brakes or steering.With the right donor truck you can make the swap for whatever it costs for the donor truck and a few parts that might need replacing like bushings unless the donor truck is in good shape.You can drop the truck with drop spindles that are readily available for the newer truck.I am not trying to make money,this is free info. If you want to know more details just ask.
found out most of front end is junk,only thing ok is center link.pass lower control arm is bent.wanting to upgrade to disc brakes.have replacement tie rods,what else will i need and from what trucks can i get the parts
| Th350 Front end play problems | bigorangechevy | Transmission - Rearend | 11 | 06-02-2011 03:41 PM |
| 1933 Chevy front end problems | Tubbed71 | Suspension - Brakes - Steering | 11 | 08-23-2009 05:22 PM |
| Front end mock up shows some problems, cut n weld or frame shop? | Ripped | Body - Exterior | 9 | 11-26-2005 07:03 PM |
| front end tilt using my all steel front end | old c10 head | Body - Exterior | 5 | 05-02-2003 01:45 PM |
| front end problems | tonylsg | Suspension - Brakes - Steering | 13 | 04-15-2003 06:47 PM |
