67 Camaro column shift conversion - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-12-2006, 09:40 PM
super_silent's Avatar
I have a 67 RS camaro with a column shift (powerglide) that I'm thinking about switching over to a floor shift with console. The car is all stock and original and I want to keep it looking factory original. Has anyone done a conversion like this ? I'm not sure on the details, specifically cutting the floor and exactly where to cut and also any wiring which would wire into the new floor shifter.
Any help would be much appreciated.
Thanks !
Mike
Old 07-12-2006, 09:55 PM
Wiki Edits: 31
I know 1 thing, the colum shift cars are very rare finds, if I were you, I'd keep it original with the colum shift. that would make it worth $$$
Old 07-12-2006, 10:08 PM
I'ts a hard decision to make matt, the car has the deluxe interior with buckets and it's in mint condition and I've been contemplating this for the last 2 years but I'm also worried about affecting the value or originality of the car.
Will power steering box from 82 camaro work in 67 el camino dave2148 Suspension - Brakes - Steering 7 09-05-2005 08:37 PM
67 camaro rally stripes 67goat Body - Exterior 2 06-22-2005 05:22 PM
Camaro VATS ignition and column RockinLocks4u Electrical 9 02-03-2005 09:34 PM
Camaro VATS ignition and column RockinLocks4u Introduce Yourself 1 01-20-2005 11:00 PM
Stick shift conversion kit cvc505 Transmission - Rearend 1 08-16-2002 09:43 PM
