67 camaro diff fluid - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-20-2005, 05:24 PM
shclayto's Avatar
I want to change the diff fluid in my 67 camaro. After draining the old fluid by taking off the cover, what do I do. There is a plastic cap that goes on a plastic nipple on the top of the housing. I can pull the nipple off but I'm not sure if that's what I should do. Am I suppose to use a pump to get the fluid inside to the gears. The oil always overflows if I just squeeze the bottle. I do not have a posi. Any help?
Old 10-20-2005, 06:34 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
should be a threaded plug on the passenger side of the main diff cast iron section. This is the fill / level check plug
Old 10-20-2005, 06:38 PM
DV8's Avatar
DV8 DV8 is offline
Sloe Lurner
Last journal entry: front boxing plates
Vent Plug
What you are pulling off is the top to the vent plug. Crosley is correct in the proper location for fill plug. You can use a 3/8 drive ratchet and 4" extension to remove it. If you have a posi dont forget to add the GM posi additive or you'll be going through it sooner than later.
Old 10-20-2005, 07:06 PM
shclayto's Avatar
Thanks for your help. I took a look at my car and it has a square protrusion (about 3/4" across flats) sticking out where the plug should be. Has anyone ever seen this before. I'm not even sure its threaded, but I imagine it has taken the place of the original plug. Does this sound familiar?
Old 10-20-2005, 10:44 PM
That means it was replaced in the past with a different plug, which in turn means it will probably come out much easier than the original did. Lucky you.
Old 10-21-2005, 04:29 AM
Perfectionist Procrastinator
Last journal entry: Moving along
I have that same square protrusion on my diff. Yes, it is a threaded plug, just has a suare head on it (I have no idea why). I was able to wiggle a wrench onto it well enough to get it out.
When you fill the differential, fill it up until the fluid reaches that hole.
Yep! I'm new 2.... Pro-Touring a '67 Camaro L8model Introduce Yourself 6 12-09-2004 12:30 PM
67 Camaro, what seats fit? Scotts67 Interior 1 06-06-2004 08:30 AM
67 camaro rearend 72 Z28 Transmission - Rearend 2 02-09-2004 05:53 PM
67 Camaro Front Springs Jim Vines Suspension - Brakes - Steering 2 04-16-2003 05:31 AM
67 Camaro steering & brakes Jim Vines Suspension - Brakes - Steering 5 01-31-2003 04:36 PM
