67 Camaro Front Disc Brakes - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-22-2007, 07:37 PM
Has anyone purchased power front disc brake conversion kit? I am considering buying one from Ricks First Generation Camaro, but am wondering whether my steering arm will fit the spindles included in kit. I have come across a similar kit for Chevy II and steering arms off that car did not fit new spindles.
Old 03-22-2007, 07:43 PM
weirdbeard's Avatar
1976 Ranchero GT
Last journal entry: Almost time for the first drive!
Howdy. Ricks first gen is a great place. My 67 has 69 disc brakes. They do bolt up. That might be a alternative solution.
Old 03-22-2007, 07:52 PM
Thanks for info
Old 03-22-2007, 09:00 PM
'67-'69 Camaro/Firebird and '68-'74 Nova (& clones) all use the same steering arms, although there are length differences depending on whether it came with power steering or not, or whether it had hi-perf steering or not. Disc or drum brakes don't matter, the arms bolt up the same. You can use your arms, or theirs, just be sure they're not A-body arms, which will bolt up, but will screw up your steering geometry.
Be sure left and right arms are the same length, or you'll screw up the geometry again. Shorter arms will quicken the steering, and make it a little harder to turn.
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
Switching 71 Camaro 10 Bolt Rear End To Disc Brakes TORI1 Suspension - Brakes - Steering 1 04-13-2006 03:38 PM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 03:34 PM
disc brakes for 1968 ford galaxie chevblazk5 Suspension - Brakes - Steering 2 08-13-2003 02:58 PM
front brakes Terry Smith Suspension - Brakes - Steering 4 01-12-2002 08:05 AM
