Building a 67 Camaro; installed disk brakes both front and back, bleeders are at the top, all new steel brake lines and hoses, new master cylinder. I have pumped fluid through it, bled brakes and have no air in system that I can tell but still no pedal. I went and purchased another brand new master cylinder, thinking maybe the first one was bad, still no brake pedal. The master cylinder on it now is for a 1970 Z28 with all 4 disk brakes. Bench bled newest master cylinder, all air out, installed on car, tried bleeding brakes. Started with furthest brake and worked way to closest, repeated many times, getting all fluid and no air, still no brake pedal. I am not running a booster, master cylinder only. Too big a cam for vacumn.
I have read that not having a proportioning valve could be my problem, I do not have one. Is this the cause of my problem
Anyone have any suggestions.
