ok i have a 67 camaro with a 327 motor with the camel hump heads so there is no holes on these heads and i am running headers and my alternator is on the drivers side the brackets come off of the headers. my question is how do i hook up my brackets for power steering with the short water pump setup is this how the z28 were setup? thank you
pump mounts on front of engine, lower left side two 3/8 bolts same holes used for front mounts on 55,57. all chevys used the same pump and bracket as camaro, along with slave cyl on center link, not a good idea, but it worked some what, cant chang to a front steer set up for use of power gear, and still be stock, tough choise good luck.JF
i have a 67 camaro with a 327 that i just built
the power steering bracket mounts on the two holes in front of the engine block and to the motor mount. hope this helps. good luck.
Related Threads
Hot Rod Forum
2.2M posts
175.7K members
Since 2001
