Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 67 Camaro pwr steering pump
Old 04-03-2012, 08:09 PM
EOD Guy's Avatar
EOD Guy EOD Guy is online now
I have a SBC in a 67 Camaro, it has a stock pwr steering pump, the old banjo style. I have a big cam so I swapped the vacumn booster out with a hydro boost unit. It works well except the fluid started to foam and then the system didn't work so well, let it sit and all is well for awhile....... so I got a remote resivoir and mounted it on the firewall etc..... the issue is the fluid shoots out the vent hole in the cap.
All the lines are stainless with AN6 fittings, two return lines from the hydroboost and the steering box into the resivoir and one to the suction side of the pump, one from the pressure side of the pump into the pressure inlet hydoboost, one from the pressure out on the hydroboost to the pressure side of the steering box
Any suggestions on how to remdy this?
