67 Camaro rear end needs new ring and pinion - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-03-2011, 10:20 AM
My wife's 67 Camaro needs a new ring and pinion. The car has a 2.73 non posi and I would like to bump it up to a 3.08 to give her a little bit more get up and go. The car has a 350 hooked up to a power glide. The problem is that 2.73 is where the carrier break is. The car is a around town driver and she doesn't beat on it. Is anyone aware of what carrier assemblies might fit into the stock housing or if there is a solution that wont require changing the whole rear end.
Old 05-03-2011, 11:09 AM
prostreet6t9's Avatar
Differential/Driveline
You might do some looking for a good/used carrier. You make get lucky and find a posi. Bad news is... Your gonna have to change the carrier. You might think about doing a 336 ratio as its a pretty good all around ratio.
Are my ring and pinion still ok? zildjian4life218 Transmission - Rearend 41 09-22-2010 11:25 AM
8.5 ring and pinion oldsmo Transmission - Rearend 1 04-19-2006 09:32 AM
Ring and Pinion fred56 Transmission - Rearend 1 01-17-2005 04:45 PM
ring and pinion help Pontiacman Transmission - Rearend 0 11-13-2003 05:09 PM
changing ring and pinion 85 regal Transmission - Rearend 3 12-04-2002 10:58 PM
