67 Camaro rear spring problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-09-2012, 12:56 PM
My 67 Camaro mono leaf shackles are faceing towards the front, and the spring is against the frame. I just bought the car and tried to replace the shocks and discovered that the shocks were in at full extention and were locked up. New shocks will not reach down to the bottom bracket. If I remove the shackle bolts can I get the shackles to head towards the back as they should? The springs are a correct Moog mono spring.
Old 10-09-2012, 02:03 PM
Pictures, pictures, this isn't making sense.
Old 10-09-2012, 09:02 PM
302 Z28's Avatar
Are the shackles the OEM shackles, if not replace them with OEM?
Vince
Old 10-10-2012, 05:36 PM
prostreet6t9's Avatar
Differential/Driveline
The bottom spring plates are different between mono & multi.. And chance those are wrong?
I have a 68 in the garage that I can get you shackle measurements and spring measurements if you need.
1969 camaro rear brake problem Johnny Bravo Suspension - Brakes - Steering 5 07-26-2007 05:21 AM
what spring and shocks for 69 camaro 1969SS Suspension - Brakes - Steering 1 08-30-2005 05:06 AM
73 Camaro Rear Leaf Spring Replacment Problems mile-hightoyz Suspension - Brakes - Steering 1 05-14-2004 08:55 PM
8 1/4 to 8 3/4 rear end Leaf Spring Problem... 71gtx Transmission - Rearend 21 04-19-2004 07:17 AM
67 camaro spring perch fork Suspension - Brakes - Steering 1 03-24-2004 03:45 PM
