67 Camaro shifter hole placement - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-15-2007, 07:44 PM
What is the correct location for the hole cutout for automatic console shifter, and what size hole.. Thanks Doug..
Old 04-16-2007, 02:24 AM
327NUT's Avatar
I have absolutely no idea what the exact measurement is but it would probably depend on which shifter you chose to use. You could take the part of the shifter that bolts to the trans. (less shift lever) under the car and figure out where it bolts up then mark and cut the hole accordingly.
67 camaro power steering 67rscamaro Engine 2 03-26-2003 05:12 AM
67 Camaro mystery plug sudo1a Electrical 2 01-11-2003 06:12 PM
67 camaro d_67_camaro Interior 5 11-28-2002 06:30 PM
67 camaro lift kit? sudo1a Suspension - Brakes - Steering 3 11-27-2002 04:50 PM
putting 68 floor shifter in 67 questions? DeathByGreaser Transmission - Rearend 1 10-23-2002 05:06 AM
