67 camaro wiring problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-02-2004, 08:01 PM
shclayto's Avatar
I have a 67 camaro and have had some wiring issues for a while. The latest scenario is such: first of all, the dim lights work fine, but I don't have any bright lights. second, when I engage the lights (parking and/or headlights) both turn signal lights come on and stay on but only inside the car. the actual turn signals themselves work fine on the outside. I believe it to be a grounding problem, but where should I start troubleshooting? Any ideas?
Old 12-02-2004, 08:09 PM
Try lowering the steering column and removing the cluster.Clean every connection and plug.Same with fuse box.High resistance on these old harnesses play games with us.
