Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 67 chevelle
Thread: 67 chevelle
Old 09-10-2012, 07:15 PM
RWENUTS's Avatar
RWENUTS RWENUTS is offline
Check your accelerator pump. Stroke the throttle with the motor shut down and you should see 2 strong spurts of fuel inside your carb. If not you've got the discharge ports plugged with something.
If all is well then check your timing. Could be retarded.
What carb do you have?
