-   -   67 chevelle (http://www.hotrodders.com/forum/67-chevelle-223864.html)
constructionsarge 09-10-2012 03:54 PM
67 chevelle
67 chevelle 283 stock cam alum. intake 600cfm carb stalls when taking for from stop signs
RWENUTS 09-10-2012 07:15 PM
Check your accelerator pump. Stroke the throttle with the motor shut down and you should see 2 strong spurts of fuel inside your carb. If not you've got the discharge ports plugged with something.
If all is well then check your timing. Could be retarded.
What carb do you have?
constructionsarge 09-10-2012 08:43 PM
67chevelle
holly 600cfm timing good ports are open
RWENUTS 09-10-2012 09:03 PM
What's your timing set at?
Timing could be retarded!
I assume timing is set per procedure. Vacuum plugged to distributor and then set to required setting.
What distributor?
constructionsarge 09-10-2012 09:35 PM
67chevelle
electronic mallory timing is to factory spec.
RWENUTS 09-10-2012 09:50 PM
Bump your timing up to 12-14 degrees btdc. Hook your vacuum advance up to manifold vac.
You need lots of timing with the crap gas we buy now.
