67 chevelle
67 chevelle 283 stock cam alum. intake 600cfm carb stalls when taking for from stop signs
67chevelle
holly 600cfm timing good ports are open
What's your timing set at?
Timing could be retarded! I assume timing is set per procedure. Vacuum plugged to distributor and then set to required setting. What distributor? |
67chevelle
electronic mallory timing is to factory spec.
| 70-72 Chevelle Chevelle dash wiring Problem | skeeveman | Electrical | 18 | 01-10-2011 07:44 PM |
| Will a 69 Chevelle rearend fit my '67 Chevelle | lt1_performance | Transmission - Rearend | 2 | 04-26-2008 10:10 PM |
| will a '69 Chevelle rear end fit into a '70 Chevelle? | SMO'KUM UP | Introduce Yourself | 2 | 09-17-2007 07:15 AM |
| 71 chevelle | richrue | Body - Exterior | 2 | 01-27-2007 09:34 AM |
| 67 chevelle 12 bolt fit in 70 chevelle? | 70chevelle327 | Transmission - Rearend | 11 | 09-11-2006 07:52 AM |
