#1
67 chevelle ignition problem/no spark in "on" position
Any and all help would be much appreciated. My car just cut out on me while driving. All the lights and everything were still on, the motor just cut out quickly and all together. When i tried to start the car, it would fire up, but as soon as i let the key off the "start" position into the "on" postion, it would just die on me again. and again. and again. So from what i can come up with, the coil isn't getting juice when the key is in the on postion. What would cause that to happen suddenly like that? I'm using an HEI distributor w/ the coil in the cap. Thanks!
Register now (free) or login to remove ads |
#2
Another way to accomplish the current reduction is to use a ballast resistor, shown in the diagram below. If you don't have a ballast (which you shouldn't if the car is original), the resistor in the diagram would be replaced by a length of resistor wire. You need to find out where the open circuit in that wire is at and fix/replace it. Good luck. ![]() BTW- this is NOT how an HEI distributor should be wired. The HEI needs full battery current w/the key in the "START" AND "ON" position. If you have the HEI wired correctly, disregard the above. |
#3
no run in "on"
check for power on the pink wire into the distributor (at least it is pink in the car that the distributor came out of). it should have power in the run position as well as the start position, but not in the off position. if it doesn't have power then start with the fuses. was the car rewired for the hei distributor? if not , there may be a resistor inline on the run position because the old points system would fry the points all the time with a constant 12v in run. the cure was to drop the voltage in the run position with a ballast resistor. by the way, the wire to the distributor power should be a little larger gauge than the old style wiring was, for better spark. if you had a ballast resistor inline you will probably notice a better spark with 12v right off the bat.
the other thing it could be is a bad ign switch. dsraven |
#5
Nothing wrong w/your gray matter- I forgot to mention the switch could be bad!
#6
I converted my chevelle to hei and what I did was went to a junk yard and found the same terminal wire off of a 72 chevy pickup and got rid of the cloth wire altogether. The wire is 12volt behind the terminal block. So far so good. I also had a bad ign switch but it wouldn't even turn over when that went bad. Hope this helps.
#7
An HEI needs full battery current to perform at its best. That means no resistor wire or ballast resistor is used w/HEI. You might not notice the lack of energy from using a resistor wire/ballast until the secondary side of the HEI system degrades or the battery is low. Then you might have hard starting and missing, etc. All that's needed is a good quality length of 12G primary wire (not resistor wire) w/properly installed terminals to get the job done. The replacement wire can be either spliced into the original wire close to the firewall connector, or a different circuit can be used that has sufficient fuse protection (15A is sufficient) like an accessory circuit at the fuse box that's hot w/the key in "Start" and "Run" positions. |
#8
Sorry for the confusion. What I meant to say is that I cut the like terminals off of the column harness and removed the cloth wire on the engine bay side and plugged in the terminal from the one I got from the junk yard eliminating the resistor wire altogether. Hope I cleared the confusion.
#9
My bet is on the ignition switch being bad.
A switch went bad on me once, with the exact same symptoms; vehicle would start but not run. If the resistor wire has been bypassed with the installation of the HEI, then it's almost certainly the switch. If the vehicle still has the resistor wire or resistor, then it too could be the problem. The way to find out for sure is locate the resistor (wire) and take an ohm reading. If it's infinite resistance, the wire is open; if reading is 1-3 ohms, then the switch is bad. |
#11
"Two Minute Job"
If you want to check the ignition switch and its "ON position" wiring, simply run a jumper from the battery positive terminal to the coil positive terminal (i.e. "hotwire" it). Then the switch "ON" position is taken out of the picture. If the engine will now start- and stays running- it's the switch or the wiring between the switch and the coil positive terminal.
To shut the engine off you will need to remove the jumper from the battery. |
#12
Wow, so one of the wires going to the starter had burned and shorted out on one of the primaries, that blew out a fuse i guess. So i rewired the starter and replaced the fuse, it turned over and ran fine. Problem solved right... wrong! I was starting and stopping the motor a lot while messing with idle mixture and the problem came back. Same deal- would crank and fire then cut out when key went to "on" position. The difference this time is that the radio and dash lights stay on after i take the key out! I tried jiggling it around to get everything to shut off but nothing worked, so i just unhooked the battery and called it a day. One thing after another! Thats got to be the ignition switch right?
#14
Replaced the ignition switch this morning, and didn't fix the problem. It did do something though, before i replaced it i could jiggle the key around and get the dash, radio, and one indicator light to flutter around. It doesn't do that now with the new switch. It'll also start and run now, its just that somehow those dash lights are getting power when the key is off. I've been trying to think what else has recently changed in the car, that starter wire burned on the header and shorted out and blew a fuse. before that I put on new water pump and crank pulleys and before that i replaced the radiator. Thats all that has changed shortly before this problem started
#15
Sounds like you're making progress.
I don't think the dash lights have anything to do with the ignition switch. They should turn on and off with the light switch, which has constant power even with the ignition switch off. Could the light switch be bad...? |
| Thread Tools | Search this Thread |
| Similar Threads for: "67 chevelle ignition problem/no spark in "on" position" | ||||
| is their a "spark arestor" in my air filter houseing ? | joeshovelhead | Engine | 5 | 07-01-2009 04:39 AM |
| Motion to change Docvette's position on the "top 25" editors banner | lowROLLERchevy | Site Suggestions and Help | 7 | 04-21-2008 08:47 PM |
| Any good "shorty" spark plugs besides Accel? | Cousin_Joe | Engine | 13 | 04-04-2008 08:08 AM |
| Ignition boxes and "performance" distribs... | BMM | General Rodding Tech | 1 | 01-17-2008 07:11 AM |
| Olds "UHV transistorized ignition system" | jimra1944 | Electrical | 1 | 09-21-2005 06:02 PM |
