67 Chevelle Sheetmetal - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-30-2002, 03:36 PM
Post 67 Chevelle Sheetmetal
I need some proffesional advice about welding in some new sheetmetal. Ihave a 67 chevelle, needing floorpans and floor braces, Rockers, Quarters and inner wheel tubs. What should i start with first? The body is stripped down to just the shell sitting on the frame. I would appreciate any help in this area.
Old 03-31-2002, 10:12 AM
jwcnj45's Avatar
Post
Before you cut out any of the floor pan or supports make sure you weld in some bracing to hold everything in place before the floors,etc. have been removed. Depending on how extensive the floor replacement will be, you might have to remove the body from the frame.I personally would start with the floors and braces first and work out from there.
Old 12-12-2002, 07:13 PM
Post
i'm not a professional, but i too have a 67 chevelle. over this past summer, i replace the floor pans, trunk braces, and trunk pans. i suggest that you start with the metal on the inside of the car first. it will make life much easier on you doing it that way. also, i strongly recommend using goodmark metal. i bought from them as well from cars inc. and i found the metal from goodmark to be of much higher quality.
what is the fastest (factory) car you have ever driven? badknuckles Hotrodders' Lounge 320 12-09-2011 01:32 AM
67 chevelle malibu emblem placement bigfoot9090 Body - Exterior 4 04-07-2009 05:40 PM
67 chevelle 12 bolt fit in 70 chevelle? 70chevelle327 Transmission - Rearend 11 09-11-2006 07:52 AM
67 chevelle ss 496hotrod Introduce Yourself 3 02-22-2006 10:38 PM
hardtop 67 chevelle to a convertible wild1dude Body - Exterior 1 03-19-2003 05:10 PM
