-   -   67 Chevy 350 tear down. What are these parts? (http://www.hotrodders.com/forum/67-chevy-350-tear-down-what-these-parts-219056.html)
gsoleski 05-06-2012 02:51 PM
I picked up this 350 with the 1000lb stand for $300. I was told it had a rod knock. This has 462 double hump heads on it too. Are these any good? They don't have accessory holes either so i'll probably sell them and find something newer. I've recently gained a big interest in engines and i'm not sure what some of these old school parts are. On to the pictures...
What kind of distributer is this?
http://i1011.photobucket.com/albums/...8/100_2111.jpg
What is this?
http://i1011.photobucket.com/albums/...8/100_2109.jpg
Q-jet carb with hot air choke maybe? The carb looks new
http://i1011.photobucket.com/albums/...8/100_2106.jpg
uhh oh...
http://i1011.photobucket.com/albums/...8/100_2110.jpg
The "knock"
http://i1011.photobucket.com/albums/...8/100_2101.jpg
Ron Golden 05-06-2012 03:13 PM
350 parts
The distributor is a points type.
The second picture is an oil seperator for the road-draft tube.
The Q-jet is also an early one, it has a perculator valve on the top---just behind the front screw on the top of the carb.
The picture of the piston is UGLY.
The crank and rods are junk and the the block is questionable.
The 462 heads aren't anything special.
I'd suggest you throw everything away, get a good book on how to rebuild a SB Chevy. Buy David Vizards book and it will step you through a rebuild.
Ron
6426yy 05-06-2012 05:02 PM
Sorry dude you got ripped off!
Richiehd 05-06-2012 06:54 PM
Ron
Keep the $300.00 engine stand
the nitro man 05-06-2012 07:57 PM
it looks like a 327 to me. also i would take it back to the guy i got it from & stick it up his ars.
454C10 05-06-2012 08:25 PM
look for a 96 to 2000 350 vortec engine. These engines came with factory roller cams and vortec heads. Should be able to get one in good condition for less than 600.00.
Only thing worth saving on that engine is the q-jet. The engine is worth about $25 at the metal salvage.
cobalt327 05-07-2012 01:25 AM
http://www.hotrodders.com/gallery/da...ium/Snap21.jpg
The carb number from the driver side of the carb will tell you the exact year of this carb. More here.
GMCBEAST 05-07-2012 07:53 PM
I also thought 327 or even a 283. It sucks people will try to rip others off like that. A rod knock, huh? You know good and damn well when you turn your oil pan into a jewelry box! Sorry about your misfortunes, maybe between that carb, intake and those heads you can make your money back. I wouldn't try to do anything with that block though it looks busted in the pics and I'm sure there's issues you can't see. Good luck.
eloc431962 05-08-2012 05:07 PM
This is just sad as heck. :boxing: :pain: :sweat: :mad:
Cole
:pimp:
S10 Racer 05-08-2012 10:52 PM
I have been in the same boat as you, believing what I was told only to find out I was lied too. I would call the guy back and tell him what you found and ask him for your money back on the motor. It never hurts to ask. The engine stand probably is'nt worth $300.00 unless it can dispense beer too. Sorry for your misfortune but I'm sure everyone here has had something similar happen to them so don't feel like the only fool on earth. Next time, ask to pull the oil pan and inspect it before shelling out money.
Blazin72 05-09-2012 06:38 AM
Take the block to the machine shop. It could still be good. I had a 350 that had thrown a rod and taken a chunk out of the bottom of a cylinder and ended putting that engine back together with a supercharger and drove it for several years.
lg1969 05-09-2012 03:26 PM
$300 for the engine, $400 - $500 at the shop. $800 You can a get a rebuild 350 motor for $800 with brand new parts. Take that engine back where you got it tell him shove it and get your money back.
1971BB427 05-10-2012 07:50 PM
That's a very early SBC, and it may be early enough that it doesn't have side mounts on the motor if that distributor is original to the motor. The later distributors did not have an oiler on them like that. If it's an early 265 or 283 without side mounts, then it wont fit into later cars requiring side motor mounts, so even if it was salvageable it wont work in many applications.
For future reference, they didn't make a 350 in 1967. Sorry you got taken by a crook.
Blazin72 05-10-2012 09:49 PM
In the picture with the broken and bent connecting rods you can clearly see the bosses for the side mounts.
The first year of the 350 was 1967.
da34guy 05-11-2012 05:11 AM
Whatcha got there is ---------
A BIG DOOR STOP
