67 chevy truck disk brakes ,HOW? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-30-2005, 06:56 PM
i just bought a 67 swb chevy and i want to put 5 lug discs on the front, i have owned a 69 that had disks, and have a 68 for parts that has disks. i want to know if the later 70-72 disk brakes will fit up to the stock spindles or do i need the spindles from a disk truck(im probably going to buy dropped spindles anyway) will the 72 spindle fit the 67 control arms, the 69 and 68 were both done with stock parts but i dont know of what year parts, the previous owner of the 69 said the front brakes were "from a 74 i think" im thinkin i could buy wheel bearings rotors calipers etc and slap em on my spindles, am i right? any one done this ?
Old 10-30-2005, 07:28 PM
ragenrat638's Avatar
CRASH TEST DUMMY !!!!!!
p.m. sent for info.....your pal mark
Old 10-31-2005, 05:20 PM
Wiki Edits: 31
use all the disc parts from the '68, problem solved. '67-'72 all has very simmilar stuff, same chassie's, parts will all interchange between chassies.
Old 11-15-2005, 04:27 PM
BIGSKY's Avatar
See project in Photo Album
The information you need can be found at www.67-72chevytrucks.com. But if my memory is correct, the tie rods changed in 71, so you would be best to get the drop spindles now before buying parts for the disk brakes. The drop spindles require that you make the switch to disks... Or put another way, they only make drop spindles [that I know of] for 71-72, not 67-70. The spindles are different again for 73 and up.
Old 11-15-2005, 11:53 PM
thanks for the info big im saving $$ for parts now....
disk brakes conversion no pressure to back brakes shiner Suspension - Brakes - Steering 10 01-24-2011 11:09 AM
429 caddy moter in 1950 chevy truck ?? cool running Engine 3 05-20-2004 05:45 AM
57 Chevy Disc Brakes.. CHEAP PLEASE 30chevycoupe Suspension - Brakes - Steering 4 05-04-2004 09:17 AM
Air ride for 55 Chevy Truck? Coleman396 Suspension - Brakes - Steering 7 01-02-2004 07:48 PM
