67 corvett BB - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-01-2011, 03:16 PM
67 corvett BB
Any ideas on intake manifold for BB, air gap won't allow aircleaner clearance need a inch
Old 10-02-2011, 09:46 AM
boatbob2
Try a drop base air cleaner,it MIGHT give you enough clearance,OR,if it doesnt,cut the base of the housing off where it meets the flat flange,add a 1 inch strip of metal.(tack) try,if it hits the hood (with top,and filter on) remove the 1 inch piece you tack welded on,and try a 3/4 inch piece, tack weld the 3/4 piece,try again.,make sure,after you modify the base that it clears your carb linkage. HAVE FUN,,,,
corvett ls1 el Engine 1 04-13-2003 10:12 PM
