'67 Cougar tilt column broken?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-28-2009, 11:36 PM
66Moostang's Avatar
I recently purchased a '67 Cougar that has a tilt away steering column. When I was driving it around the block the other day, the steering column went into "tilt" position out of no where and I'm not sure how to get it back into place. I wasnt touching anything but the steering wheel. It didnt really make any cracking or popping noises and I don't want to sound like a complete newbie but i have never worked with one of these before. I dont know how to get it back in place and I'm just about certain somethings broken.
Old 05-29-2009, 01:56 AM
machinist & fabricator
use a porta power and dukt tape
Old 05-29-2009, 10:05 AM
bobjob's Avatar
I rebuilt quite a few tilts...its a bit of work to rebuild it ,,but its nothing too difficult.. at a GOOD auto parts store,, or restoration site,, get a exploded view...parts tear down ..on tilt steering column..
you are going to have to remove a lot of parts,,it's probably tilt latch tension spring..
good luck ..if any problems send me a message...
Old 05-29-2009, 10:28 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
You DID try the actuator for it, right?
Old 05-29-2009, 10:39 AM
bobjob's Avatar
if you lift up on lever,,will it stay up??if so lift it up,, hold lever up with stick till you can "tear down and do it right..might take quite a few hours.. may take a few days for parts.. i think they sell a rebuild kit ..
has most parts..depending on whats wrong..
56 Chevy Tilt Steering Column Swap slickstick56 Suspension - Brakes - Steering 1 05-04-2009 09:24 AM
1978 Camaro Tilt Steering column CamaroHunter78 Interior 5 02-14-2008 02:19 PM
best tilt column 4b316 General Rodding Tech 5 01-14-2008 03:25 PM
Steering Column Install Quarter Flash Suspension - Brakes - Steering 3 05-10-2007 11:36 AM
Fan hit upper rad. hose!! mustangdude947 Engine 14 08-19-2004 03:52 PM
