67 Cruiseomatic issue - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-02-2011, 09:56 AM
I just purchased a 1 owner completely original, 1967 Ford Country squire station wagon, 390 ci, 3 speed automatic (dealer invoice says in hand written type includes Ford Cruise O'Matic), car was purchased new on 11/23/66 and at 56,000 (156,000) on Odo it had a trans rebuild, it now says 99,400 mis (199,400) I drove the car home 200 mis. yesterday and was turning onto my street and noticed a puff of smoke by the pass. side fender, I pulled into my driveway and looked under the car and a puddle of fluid 2 ft. x 2ft was forming, I started the car and pulled it directly ahead into my shop and shut it off, trying to get an idea as to what was the problem, as I have found a few things it seems it could be, a vac. modulator?, or vent plugged??, if I need a modulator can I purchase that locally or from you?, it shifted and ran and drove fine all the way home except for above mentioned time, thanks any hints,info is appreciated; Geof Amos; Vancouver, Wa.
Old 10-03-2011, 08:33 PM
Wiki Edits: 27
ford fires
There was a batch of Ford fires when the trans was over filled and it would puke Trans fluid on to the hot exhaust system..
Best 60s Issue of Hot Rod Magazine and best 50s Issue of Car Craft MXrider13 Hotrodders' Lounge 18 07-29-2011 01:55 PM
vacuum issue or carb issue idk for sure chevyok06 Engine 1 07-10-2011 05:19 PM
220 V issue kleen56 Garage - Tools 9 11-07-2009 05:16 AM
Cruiseomatic leak Radchop Transmission - Rearend 5 07-31-2008 02:25 PM
10-12 Bolt U-joint Issue Issue MrB Transmission - Rearend 3 09-29-2007 08:17 AM
