67 el camino steering & suspension problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-15-2005, 07:59 PM
I have a 67 el Camino original, have rebuilt front steering, all new components, ( new center-link, drag link, tie rods ends everything, even new close ration power steering box, shocks sway bar bushings) new air shocks in rear, had the vehicle aligned and still getting wandering on the roads when road is semi rough
any ideas
Marty
Old 12-15-2005, 09:47 PM
TechnTool's Avatar
OldSchool MotorHead
Post the alignment specs, as measured and what the recomended settings are. you are describing too much caster. Also, how are your tires. Are they overinflated, did you try retoating them front to back? Many alignment places only set the Toe and nothing more. Repost with more info.
Old 12-16-2005, 03:37 PM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
You stated all new components, did that include ball joints, bushings.?
Old 12-16-2005, 05:47 PM
67 el camino suspension
Thanks for the reply
i replaced, steering box (close ratio), all tie rod ends, both inner and outer, centerlink, idler arm, draglink, new shocks, all bushing for sway bar, had ball joints check, at alignment shop, they said ball joints ok.
Marty
Old 12-17-2005, 05:40 AM
TechnTool's Avatar
OldSchool MotorHead
I still wanna see the alignment specs.
Old 12-17-2005, 05:06 PM
Alignment Specs
Im trying to locate them, the wife move folders on me and she can t remember where,
also i will try and find the factory specs
Marty
El Camino question Echofive Interior 8 07-25-2006 09:45 AM
adapt 94 IFS onto 66 el camino Echofive Suspension - Brakes - Steering 5 05-21-2004 10:21 AM
Finding 72 El Camino Disc Brakes sb72elcamino350 Suspension - Brakes - Steering 2 03-19-2004 06:35 AM
67 el camino elec. digram 4 ignition & wipers 67camino Electrical 5 12-19-2003 06:28 PM
'94 Firebird steering problems ILjXYZ General Rodding Tech 4 11-07-2003 10:26 PM
