67' Fairlane GTA 2dr hardtop 1/4 panels - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-17-2003, 04:35 PM
New Member
Post 67' Fairlane GTA 2dr hardtop 1/4 panels
My 1/4 panels are spliting on both sides at the rear window line. I was told that it was from body flex because my 390 makes alot of torque. I've also been told that convertable GTA's had sub-frame conectors to tie the front and rear sub-frames together, so I'm looking into that. My question is how do I stop the exhisting cracks from growing? One suggestion was to drill a small hole at the end of the crack and then weld it up. Will that work?
Old 05-17-2003, 04:50 PM
adtkart@aol.com
Post
To help stop the crack from spreading, yes, drill a small hole at the very end of the crack and then weld it(the crack) up. If you try to just weld it without drilling, the crack will continue.
