67 firebird th400 info - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-10-2002, 04:21 PM
New Member
Post 67 firebird th400 info
someone help me please, I just pulled my ohc 6cy out of my bird. I am replacing with a 68 400 and th400 trans out of a bonn. the th400 is a long shaft. would you install and cut driveshaft or rebuild th400 and use shortshaft. The trans and engine have 52K doc. miles on the setup.
Old 12-10-2002, 04:45 PM
BOBCRMAN@aol.com's Avatar
Post
get a driveshaft made it's cheaper thans a trans build.
Old 12-10-2002, 05:31 PM
Post
Be aware that the crossmember mounting point for a long Turbo 400 is 1 inch or so further back than a short Turbo 400. :p :p
