67 Ford Truck Tranny cooler lines questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-29-2010, 07:57 PM
Hello, I am building a 352 motor for my son and trying to keep the 67 tranny in it. The big question is how does the tranny cool through the radiator? When we pulled the motor, one line comes off the tranny and "y's" into the block on each side, and one line runs to the front and hooks into the bottom radiator hose. any ideas, or info would be great help..Thanks Jeff
Old 09-29-2010, 08:29 PM
Crosley's Avatar
Wiki Edits: 1659
Jeffemtb.. welcome to Hotrodders.com
We do not use HELP in thread titles here. We know you need help. I edited the thread title to reflect your questions on cooler lines.
There should be 2 cooler lines on automatics that have remote cooling. Some early automatics did not have external coolers, only air cooled.
The lines you describe may contain engine coolant , not trans oil. Some early trans coolers were plumbed into the engine water via heater hose lines that run to a trans cooler located at the trans case
Old 09-30-2010, 07:49 PM
It is water cooled through the radiator. I am trying to get away from putting a "T" in the lower hose. Would a smaller radiator work for the trans cooler, mounted in front of the regular radiator? Thanks Jeff
All right all you Ford guys, a couple of questions Shades_o_Grey General Rodding Tech 8 12-28-2010 06:00 PM
Ford Steel Wheel Tech wheelkid General Rodding Tech 9 01-07-2007 06:31 PM
I loved the girl and her dad's Ford truck T.C. Introduce Yourself 5 07-30-2006 05:49 PM
Tranny Temp with a cooler? Seon Transmission - Rearend 19 12-26-2005 09:38 PM
66 ford truck swapping a 240 i6 out for small block chevy igotachevyor2 Engine 0 04-14-2002 03:19 PM
