67 fury III wont start!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-26-2009, 06:04 PM
it has to be electrical. i put new alternator, new battery, new voltage regulator. still will only start when jumped off. any ideas? i need help fast! thanks
Old 09-26-2009, 07:07 PM
poncho62's Avatar
Wiki Edits: 5
Bad starter solenoid.....Break in wiring
Old 09-27-2009, 08:14 AM
A little more info than "won't start unless jumped off". What happens when you go to the "start" position with out "jumped off"? Does the motor spin but not fire? Is there a solenoid click when you go to the start position? What do you mean by "jumped off"? Are you hooking jumper cables from another vehicle to your battery? Are you hooking the positive cable to the battery cable lead at the starter? Are you hooking the cables to the solenoid terminal?
Trees
Old 09-27-2009, 10:39 AM
T-bucket23's Avatar
Wiki Edits: 26
What exactly is "Jumped Off". If you meen it starts with jumper cables, either your battery is junk, bad connection(s) at the battery, or the battery is not being charged.
What is the voltage at the battery while not running and while running.
More information will help to get you fixed.
Chet
Old 09-27-2009, 08:09 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
Bad ammeter will also do this.
I had 2 67 Chrysler 300s
Both of them went thru ammeters like candy.
Even after the wiring harnesses were changed
Old 09-27-2009, 08:20 PM
joeyb's Avatar
if it rolls over try the balist resistor (sorry about the spelling) if it dosnt roll over try the starter solinoid. my dad has a 66 fury 3 drop top and the same thing happened
crank no start meev182 Engine 7 06-17-2007 06:27 PM
Car wouldn't start thismorning topdogger Electrical 15 05-07-2007 05:05 PM
chevy 350 won't start Troy Smedley Engine 2 03-23-2007 05:21 AM
My truck wont start. 91 serria 350 tbi montea Engine 17 12-17-2006 04:23 PM
'67 'Cuda 273v8 won't start makit3d Engine 9 02-27-2004 07:24 AM
