67 GMC 3/4 ton truck brakes - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-13-2010, 02:16 PM
it has drum brakes on it now would like to change to disc been told that any thing from 79 to 85 will be a direct bolt on does any one know if this will work?
Old 06-13-2010, 11:45 PM
DOCTOR DC's Avatar
NUCKINFUTS MOTORSPORTS
you have to take everything including the lines, EVERYTHING.
Old 06-14-2010, 12:08 AM
fast68's Avatar
likes chevy trucks & boobies
hi there kandydude welcome to HR forums.
well anything '71 72 or '73-87/'91 are the chassis year changes groups on the full size GM trucks blazers jimmies burbs panels etc.
upper balljoints different too
otherwise take everything from the donor truck
there is an oval shaped hole in the frame rails on these 72 older trucks where a brake hose end will be able to pass through and be attached to the frame, this is in front of the control arm, in the frame rail itself.
keep all partsd you get for it the same year bnecause the calipers did change slighlty a few times over the years
and 71 72 are unique to those two years so are the brake rotors they have a cooling groove in the pad face of them these two years i dont know why,
in 73 they did away with this groove inthe rotors. and changed the cvalipers and hoses also
and,....... in 73 the control arm bushings on the 1/2 tons changed to rubber non greaseable
72 older all were solid greaseable bushings
in 73-up the 3/4 ton and 1 tons still were solid type CA bushings just like the 72 older all series.
i like to unbolts the entire cradle and crossmember assembly as a complete unit from the donor truck and bolt it to the frame rails of the 72 older truck chassis
any specific info or factory info or factory specs or numbers needed let me know i have bilions of sheets, books, specs, rpo code lists and model code lists and info here for the gm trucks most years of the 60s and 70s and 80s etc. i can get you pics of the original factory specs drawings and other interesting things too.......
Old 06-14-2010, 09:20 AM
Sinister's Avatar
I got disc brake stuff off a '72 Chevy 3/4 ton for my '69 C-20. Calipers, rotors, spindles and drag link. Should be able to use '72 ball joints in my '69 a-arms. I'm waiting though cause everything in my drum brake setup is brand new. Will probably go 4 wheel disc with these brackets: http://www.ruffstuffspecialties.com/...ket-p-289.html
Another good link for you is: www.67-72chevytrucks.com
1950 3/4 ton brakes Braindead Suspension - Brakes - Steering 3 07-05-2007 10:37 AM
1973 el camino/1950 GMC 3/4 ton. tumbleweed1 General Rodding Tech 4 05-29-2007 01:40 PM
1948 Chevy Thriftmaster 3/4 ton truck 5 window therock Suspension - Brakes - Steering 10 03-25-2007 12:57 AM
Lost power assist !!!! 1970 GMC Truck digtaz Suspension - Brakes - Steering 2 04-16-2003 06:46 AM
1970 GMC Truck Disk brakes digtaz Suspension - Brakes - Steering 20 04-03-2003 09:39 AM
