Hotrodders Bulletin Board
#1
67 GTO Column Harness terminal pins
I have a 67 GTO Convertible I am re-wiring with an EZwiring kit. The kit comes with the newer straight flat column connector where mine has the curved half moon shaped connector. The connector is in good shape but rather than spice in the new harness to the old wires I would prefer to crimp/solder in new terminal pins directly to the new harness. Trouble is I have not been able to identify or find a replacement for these old terminal pins. Does anyone know what Packard Electric called these old terminals and where I might find some? They look to be the same pins used on the firewall to back of fuse panel. They are not the Packard 56 series as I have already identified those terminals and ordered some from Waytek Wire. Any help would be much appreciated.
#2
GTO harness pins
Try this place. I bought a few hard to get things from them. Top quality too.
http://www.lectriclimited.com/mainpage.htm Also I was looking for pins for my fuse block. I found what I needed at an electronics store. You might go take a look. You might find something that will work. Rich |
#3
re: 67 GTO Column Harness terminal pins
try your local gm dealer, we have a HUGE 'kit' of terminals [12-15 trays, kit is actually a gm special tool], when i converted my chevelle dash to gauges, i found the terminals i needed in that kit.
#4
Go to your local auto parts store and have them search their electrical Book. They make a conversion kit already made up to go from the flat signal connector to the half round style. I just gave two of them to my brother last week.
Joe Garcia http://www.50chevy.freeservers.com |
Back to top |
Similar Threads for: "67 GTO Column Harness terminal pins"
| Steering Column Install | Quarter Flash | Suspension - Brakes - Steering | 3 | 05-10-2007 11:36 AM |
| Wiring Kits | crazygutgut | Electrical | 40 | 12-15-2005 07:49 AM |
| Steering Column Harness on a G-body | 1982 SS | Electrical | 2 | 07-29-2005 01:06 PM |
| cant find 12 bolt posi 3.90's for 67 GTO | Quarter mile killer | Transmission - Rearend | 4 | 09-06-2003 09:38 PM |
| wiring harness for '69 GTO | cleaner21 | Electrical | 1 | 08-13-2003 08:25 AM |
