Build hot rod how-to articles
100+ user-created articles:
'37-'57 Buick Olds Pontiac suspension upgrade, Body-exterior tips, Bulletproof cooling system, Buying a trailer, Cheapo paint job, Cold air intakes, Cylinder head choice, Determining TDC, E85, Epoxy primer, First paint job, Free T-Bucket plans, GM transmissions, Head gasket, Header design, Health and safety, How to find an electrical drain, How to title a hot rod, How to identify a Ford V8, Make a fiberglass fan shroud, Media blasting, Patching a body panel, Pitted rust, Pre-1980 VIN decoding, Removing stuck fasteners, Rewiring a vehicle, Waterproof panelboard, Why not to use a SBC engine, and many more...
Hotrodders Bulletin Board > Tech Help > Suspension - Brakes - Steering
  #1
Old 05-15-2008, 01:06 PM
firechicken383 firechicken383 is offline
67 gto disk brake conversion info needed
Hey there, I have a friend that is starting a 67 gto build. It currently has drum brakes on the front and he was looking for swap info. He is wanting to search and find front disk brakes off of something else to swap over.
I have heard 67-69 camaro, and I would assume 67-69 firebird will swap as long as everything else is swapped, like brake hoses, calipers, rotors, spindles, etc.
Can anyone confirm this?
Thanks very much.
Old 05-15-2008, 01:39 PM
matt167 matt167 is offline
 matt167's barnstar
Wiki Edits: 19
re: 67 gto disk brake conversion info needed
anything that is made to fit a Chevelle will also fit that.. Speedway Motors has a kit that will fit the Chevelle.. it's actully listed for GM midsize but in there Chevelle section.. ( GM Midsize includes Chevelle, GTO, Lemans, Cutlass and a couple others )
Old 05-15-2008, 04:08 PM
joe_padavano joe_padavano is offline
The 64-72 A-body (GTO, Chevelle, etc), the 67-69 F-body (Camaro/Firebird), and the 68-74 X-body (Nova and clones) all use the same spindles, rotors, calipers, and mounting brackets. You need to use the steering arms from the GTO, since the F-body and X-body arms are different, but these are bolt-on anyway. There are lots and lots of kits available for this swap. As noted, Speedway Motors has about the best price I've seen.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "67 gto disk brake conversion info needed"
Brake conversion 67 chevelle- 71 nova nasty nova'71 Suspension - Brakes - Steering 3 06-05-2007 10:27 PM
Disc Brake Conversion On 1937 Plymouth jjp Suspension - Brakes - Steering 1 01-30-2007 12:17 PM
Chevy 10 bolt disc brake conversion Hersch Transmission - Rearend 11 12-26-2006 05:57 PM
Ford Galaxie Disc Brake Conversion CrashFarmer2 Suspension - Brakes - Steering 2 12-07-2004 10:35 AM
Disk brake conversion need help Loup Suspension - Brakes - Steering 3 08-18-2004 05:12 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
